1 - 3 of 3 Posts
I have a 2006 1800 and am considering purchasing a headlight modulator. Does anyone out there use one and if so can you recommend a company.
Griz440
i installed one on my 1500 it works ok but i don't use it much, it makes other people upset, a guy on a hd yelled at me once, it really annoys cagers. but when i am coming into a busy intersection i turn it on before i get there. The guys at cycle max are the best here is the link.
This one, get the jumper kit they make now to for the dual headlights on the Wing.
Modulates both high and low beam. Hit the horn button and it flashes the lights at the same time as the horn .
Just touch the horn button and you can set the intensity of the headlights to two amounts of brightness.
You can turn the modulator on or off on either beam at any time.
It is called the Diamond Star, by signal dynamics.
DiamondStar_Instructions.PDF (application/pdf Object)
1 - 3 of 3 Posts
