I have an 89 GL1500 with a later model headlight. I want to install silverstar bulbs in it, so I need the adapter rings. I called my local honda dealer and parts person said it would not be a good idea to install them. He said that the higher wattage bulbs will melt the chrome plastic inside the assembly. Is this true? I am also looking for a whiter bulb for the cornering lights. I have them set to stay on all the time when the bike is running. Any suggestions?
Trike Master
That is possible. The 1st thing you may notice is a discoloring(haze like fogging and/or darkening) of the housing reflector surface just above the bulb.
I did not notice a significant enough improvement to warrant the higher cost, nor the short bulb life to keep these bulbs in my 1800.
Other opinions may differ!
While the dealer has expressed a sensible concern, I installed PIAA's in my '98 headlight assembly (which is also the newer headlight) some years ago without any ill effects - and here in Canada, the headlight is on whenever the bike is running. I assume this is the same with the American model.
PIAA does make a headlight bulb which is billed as a vibration resistant model - you can check the PIAA web site.
They also make a bulb which fits your driving lights which I have installed and am very happy with. Are just a little expensive, though. Check the PIAA powersports section of their web site.
All these bulbs should be available at a local car parts supplier, but I hear nothing but good things about the Silverstars, as well.
The shims or adapters you are talking about should be available at any Goldwing aftermarket supplier. I use Cyclemax, but I have found them on other sites.
Now, go forth and illuminate without apprehension!;)
T.
Have reread your post and note that you have an '89.
Not sure if the driving light bulb from PIAA that I use in my '98 fits your year. I know the standard bulbs are different, but not sure if they are interchangeable.
In any case the PIAA driving light I used is the H6N and I really like the whiter light.
Good luck!
T.
Oh - THAT guy...
The Silverstar bulbs are the same wattage as normal bulbs. Well, very close anyway- stockers are what, 45 watt, and the Silverstar are 55. I run mine without the adapter rings with no ill effect, though I have been told light pattern is better with them. However, I have awesome light coverage at night so no complaints.
They have a shorter life rating, though mine have been in over two years and I ride quite a bit.
Good luck!
T.
Thanks for the info, My bike is a 89 with a 98-2000 headlight assembly.
