Hi all, i wonder if anyone can help with an annoying problem? The other night I was at a friends house and we had the false tank top off to lube the idle adjust cable. Everything went back fine and and runs great, however on the way home i switched on the highbeam and was promptly plunged into pitchblack forested road. With the hazards on I managed to VERY SLOWLY drive about 3 blocks to the nearest lighted area. When a friend arrived with his van (for me to follow home in case the lights didn't come back) I changed the fuse and had lights, but less then 5 minutes later(after trying the highbeams several times) they headlights went out again. I haven't taken it apart yet to see if I pinched and shorted out anything yet but will do so this weekend. Hopefully it will be something simple like that but any and all suggestions are welcome. Thanks in advance.
Gregarious Greeter
Sounds like you are looking in the right direction to me.
Gregarious Greeter
busdriver wrote:
There's a loose nut behind the wheel.
:cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1::cheeky1:
Thanks rob....remember you were the one that helped and a loose nut yes but remember its a wingnut :cheeky1:
