i have an 83 interstate i would like to upgrade the headlight (my opinion it is to dim even on high)
does someone make a replacement round headlight that you can put in the newer high output bulbs?
i have seen them in square but not round
thanks
PAF1047, a few years ago I changed out the headlight on a 1100 with one I got from JC Whitney. It is in the auto catalog Part#WW495315 47.99 a pair, picked up bulb here in town. Worked great.:waving:
I copied this from past forum post. See if this is what you are looking for:
GL1100 Headlight Bulb, Silverstar H4 ST For Motorcycle Use Only
I bought a replacement 7in headlight housingfrom autozone that had the clear diamond cut lens for about 15$ it takes all H4 bulbs and that made a very big difference with a silverstar bulb before I replaced the headlight housing the silverstar helped but jst didn't do the trick
I replaced my sealed beam with the SylvaniaXTRAVISION H6024. I examined the reflector in the headlight and found the shiny coating was mostly gone so I replaced it with a sealed beam H6024, fits right in and provides much better light.
i went there last year the guy i talked too looked at me with that blank look on his face like what ######## are you talking about, then i showed him his instock square but i wanted round still that dumb look
1500 winger pointed me to jcw for the car they have a set of 2 with the bulbs for 47.99 plus tax or you go to the cycle section 1 for 45.99 plus tax but no bulbs
i would think a 7" bulb is a 7" bulb?
