Heres my problem, need your help and experience, maybe someone has run into this.
Turn on ignition key, no headlights come on.
Start bike, low beam comes on most of the time but not always.
Flip to high beams, lows go out, highs do not come on, flip back to low and nothing on, no low or high.
Shut off bike, start again, lows usually come on but not always, if they do flip to high, both sets out.
When set to high indicator light on dash panel does not come on. Both high and low beam fuses are good, I replaced both in case there was a hairline crack in either fuse but no good.
Sprayed the rocker switch with silicone spray, and multi cycled the switch to ensure clean contacts but no good.
Any suggestions? Thanks in advance.
