Discussion Starter #1 (Edited by Moderator)
I have a 2004 goldwing the headset volume decreases while moving then goes back to normal when I pull clutch in, I've tried different headset and changing to passenger connection the volume for both radio and headset any ideas?
That's an odd one. I suspect a ground problem or the noise filter was left disconnected after an air filter change.
I checked the filter it’s plugged in also when I pull in the clutch the volume returns to normal
Where is the ground I should check?
It is solid dark green wire coming out of the radio, it goes to the filter and then to the frame under the fuel tank.
