I am working in my 2002 1800 GOldwing and un the install instructiuons for kit states that there is stock plug in under right side panel on the OEM wiring harness.
Haing much of the right side removed to complete install still can't seem to find plug in.
Anyone have the answer as to what I'm missing?
Older and Wiser
You should be able to see it when the pocket on that side is removed. It's coming out of the bunch of wires near the ECM outputs.
Older and Wiser
The article does say that;
"On 2001 & 2002 models this connector (clear coloured) is just under the right side air vent (below the speaker). The white connector (third picture) plugs into the heater controller. You can now fit the controller panel in place, but make sure that the back of the controller and the lock mechanism do not foul the wires or radiator hoses before bolting up."
Thanks to all found the darn thing and finished the install, Man this is a great site!:clapper:
