1 - 16 of 16 Posts
Hello everyone, I need some help please.
I have a heat pump heating and air conditioning system.
My system, approx 10 years old, has failed. I had to replace my compressor about a year and a half ago, (under waranty on parts) and it needs to be replaced again, (still under warranty on parts). But I also have to replace the evaporator "A" coil due to a leak, (not under warranty.)
Estimate is $1100.
My repair guy says this compressor should have lasted longer than a year and a half, but not a lot longer. Once they fail, the system gets contaminated and you can never get it all out. He thinks that 2-3 years is common for a replacement compressor to last. Probably the leak in the A coil added additional strain and caused mine to fail early.
If I fix it, I have a 10+ year old system that will likely fail in the next couple years. (next time it leaks?)
So, he says it's a good repair, and he has no qualms about doing it. But he suggests that I replace the system.
New system estimate is $3800.
Old system is 12 Seer. The new would be 13 Seer.
Old system is a Janitrol, the new system would be a Janitrol.
Some interesting math I was thinking about, $1100 if it lasts 2 years is $550 per year. A newsystem at $4000that lasts about 10years is $400 per year. Broken down per year, a repair is only a little more than a new system.
I'm not particularly impressed with Janitrol. It did the job, but it only lasted 10 years. (The original system in the house was a G.E. and the condensor/compressor unit it lasted10 years, but the evaporator/air handler unit lasted 20 years. My current system makes some noises as the freon flows, not bad but noticable. Other than that the system did a good job.
So I could live with another Janitrol, which is the brand my AC guy handles. But I have a neighbor that has Carrier and loves it. So maybe I should go after the "better" brand? Probably more expensive, but would it be worth it? My neighbor recommends I go with his guy and get a Carrier.
I mentioned this to afriend, and he said right away, 1)replace/not repair, because if I repair, it's just throwing money away. 2) he said go with at least a 15 seer unit so that I can get the $1500energy taxcredit.
So if I go up to a 15 seer unit, I don't have a quote yet, but I am speculating about $5500-$5800 based on what my neighbor paid for his Carrier(s). (he hastwo -2 1/2 ton systems in a two story house, I have one 3 ton system in a one story house. His were $5500 each.) Deduct $1500 for the tax credit and that would put me at about $4000 - $4300. For an extra $2 - $500, it would be worth moving up in the energy efficiency.
But, I'm really going totearup what I have in savings. My house really needs several repairs and upgrades that I have been putting off as it is.
Oh, if I go to the higher seer rating, and use the tax credit, then I can't use the tax credit on replacement windows, which this house really, really really, needs. So in most cases going to the higher rating would be a no-brainer. But if I do that, my windows, when I do them, if I do them next year will cost me $1500 more. (a bird in the hand is worth two in the bush comes to mind.)
Any opinions?
Repair or replace?
Stick with Janitrol or go to the more expensive (but hopefully better Carrier)?
Go with the higher seer to get the tax credit, or go with the less expensive unit and save the tax credit for windows I can't afford, but I really need?
Can anyone tell me how much difference there is between 13 seer and 15 seer?
Thanks in advance.
Get the best system you can afford. They are getting more and more energy saving and more efficient. So if you can get a tax break, less cost every month to run it and a better lasting system, you'll be money ahead in the long run. I feel for you.
I have repairs needed too and know that as soon as I start making some money again, its' gone before I see it.
:shock:
I would get a new guy and a diffrent brand, my 2.5 ton unit has run 15 years with no issues
Xenforo vehicle detail line
My home has 2 Ruud 2.5 ton units on it. One of them was installed in 1982 and is still running. The 2nd one is a different shape and style, low profile for some reason and appears newer. But it is still over 20 years old at a minimum per my a/c guy.
10 years is normal? You need a different a/c repairman and brand of unit.
I love the new Trane super high efficiency units. BUT? how long are you personally going to live in that house? It would take an awful long time for this system to break even and start making you money.
My a/c guy told me to forget about the new super high efficiency units, even if the ones I have now go kaput. Why? He says there is NO WAY for me to get my money back even with the lower energy costs for the better units. Either I won't live long enough, or, I will sell the house.
He is right, the house is going on the selling block this year, I can't afford it anymore. I signed my retirement papers yesterday.
We bought our home 6 years ago this past October....The A/C unit had been here for a number of years and was working great....With the additions made to this house, All professional done, the unit I had was a bit under rated for this house...So I would cut off or down on the number of rooms not in use....We were on a job site where the home owner was adding about 1200 sq ft to their existing home...Our A/C guys brought out two new 4 ton units to replace the one 5 ton unit that was there.....I asked the A/C guys how old that unit was???? He said less than two years old.and then I asked what they were going to do with it????? I was told that they were going to trash it out for usable parts...So I asked if they would give it to me????
I brought that unit home, set it in my garage, spun the blades on it every couple of weeks or so....It wasn't 8 months later it happened.!!!!!! My unit went totally out...Called the A/C guys that took that unit out at this other home.... He went into the attic, found out that every thing up there was newer than the existing A/C unit.....Every thing in the attic was for a 5 ton setup ????? They took that newer unit installed it and for 4 years it has given me great service....It also cut down on my electric bill some, My cost????? 5 ton unit ....Free.....Labor to install it.....$100.00....
BTW it is a Trane....Carriers are good units and like you to replace my existing A/C with a newer unit just for the tax credits, I had rather use them, if I decided to, change out all my windows...
Wolfman, I am a 20 year HVAC Technician. Witht hat said, I will answer a few of your questions....
False... if you have a knowledgeable tech, he would know that they make a solution that cleans out the system, after a compressor blow out. I have used this "cleaner" many many times, in 20 years and have never had a compressor die after only 1 year of service. If cleaned properly, and a filter drier is put on the liquid and vapor lines, that compressor will last you as long as the original. My bet is, when the compressor was changed out, that is all that was done...a quickie change out.
That is because the government has mandated that 13 seer is now the lowest rating a manufacture can make. 12 seer is no longer available.
Carrier, Bryant, Lennox, Ruud, Goodman (Janitrol).... or any other brand, is just as good as the other. I have installed every brand known to man. They are all equal in the parts department. The difference is warranty, case design and how they were installed, to begin with.
Keep in mind.... MOST compressor failures are not due to the equipment, but due to lack of maintenance or power issues. The number one reason for compressor failures, that Ihave seen, is lack of maintenance by the home owner, or servicing company. Dirty evaporator coils and/or dirty condenser coils makes the top of my list. Next on the list would be power issues in the home...IE: frequent power surges or low power issues. Thermostats have also been an issue a few times. Some people have the old mercury round thermostats (T87) which have no time delay built in to them. Match that with an older system, with no time delay, and you have a disaster waiting to happen when the power surges.
Not so in Iowa...but Im not sure about Virgina. In Iowa, these 2 credits are completely separate of one another. We install HVAC equipment in new homes, which also have high eff. windows, insulation, water heaters and so on, and they still receive credit for each of these. Remember, there is a federal tax credit, and then there is also your local utility CASH REBATE, for installing high eff. HVAC, appliances, windows and so on.
Not only do you receive a tax credit, but you should also receive a cash rebate from your utility company. Keep in mind... most utility companies require you purchase AT LEAST a 14 SEER unit to qualify for the cash rebate. For the tax credit, it is calculated on the total installed cost...a percentage of it. Read more about the tax credit HERE.
So now my opinion....
Repair or replace? If I had a reputable company that cleaned the system and installed filter driers, I would have no issues replacing. Your unit is 10 years old... life "expectancy" is about 15 years. Its not really a life expectancy, but more of an amount of time that the manufacture considers that the unit will remain at the efficiency it was rated at, when new.
Your 10 year old unit has probably dropped to a 11 or even 10 year seer, just from age.
If you plan to use the same company to replace the second compressor, I would opt for replacement. The one thing I would make damned sure of is that if they install a high efficiency A/C and furnace...I would assume it is both due to the price of the estimate, that they match the system. If not, rebates and tax credits will be denied and you will be left with a dead horse in a few years.
One other thing... the tax credit has a $1500 cap, over 2 years, I believe it is. You can claim 30% of the installed cost for the credit. So, that would be $1140 on a $3800 system.
REMEMBER this though... this is a tax credit!!! not a rebate. This is nothing more than a $1500 "right off" on your taxes...if you are self employed, this is a huge help. If you are an employee, with taxes being withheld for you... $1500 tax credit is not that big of a deal.
I hope I helped a little.... if you have more questions, Im happy to help.
Dean,
Thank you very much for taking the time to explain that so well. I just bookmarked your post for my own edification when I need it again.
Hi all,
I appreciate the input.
Dean,
Really awsome info. I really appreciate you taking the time to really explain.
What do I need to specify to make sure he does? do I just tell him to make sure he cleans out the system?
Also, 2 filter dryers? My system only has one. So If I specify I want two, it's not going to be a problem for him?
Also, I don't think the dryer was replaced when they replaced the last compressor. I can't swear to it, but I think the one on there now is as old as the system. There is rust on it. it's older than a year and a half.
Called my neighbor's guy today. He is going to come give me an estimate tomorrow morning. He sells the Carrier.
He is definitely a Carrier man through and through. He told me that Janitrol/Goodman was about a 10 year system, and the Carrier was much better built and I could expect 20 years out of it. So I guess I need to take that with a "grain of salt." Thanks for the heads up there.
No hard evidence here, but I lost my dishwasher the same day as my compressor went the first time. It had to be a power surge... I am convinced of that.
This time, I am pretty sure it's the leak. It has leaked down a couple times and been recharged but until recentlythe leak was really slow and we never did a search for it. 2 months ago he came out and this time did a search for the leak and found three leaks. Both of the lock out valves were leaking, so he put some gummy stuff under the caps. And the evaporator coil was leaking. We talked about replacing it then, but with budget constraints, we tried a can of stop leak. The tech said he had had really good experience with it. He had one customer that was leaking down very quickly and they used it and it's been several months that it hasn't leaked down. So I decided to try it.
The first time the compressor went, all the freon went out. This time there is still freon in it, but can't tell how much.
I think that low freon pressure is a contributing factor in this failure.
Yes, it would be a matched system, replacing both halves of the system.
I'm wondering about the lines that run from outdoor unitto the indoor unit. Do I need to replace them? They arestill the original ones, 30 years old.
Wolfman, Dean gave you some valuable information. I worked in the A/C and Refrigeration field for 35 years and I can assure you that if your A/C man said a system cannot be cleaned up after a compressor loss them you are dealing with the wrong person.
Discussion Starter #10
That's good to know.
In all fairness, I may not have quoted him exactly. Between talking toa couple friends I may be mixing some conversations. What I remember that he did say for sure was that he would have expected that this compressor should have lasted longer, but not a lot longer. They usually didn't last like an original one would. But he didn't say how long. It was one of my friends that was explaining why that was, that told me about getting trash in the system.
That being said, when they put the replacement compressor in a year and a half ago, I don't think they cleaned up the system, although I don't know what that would look like. They could have done it and I didn't see it. I alsodon't knowif they put in a new filter dryer.
But I do know I had a leak, and didn't fix it either. So rather than figuring out blame, I just need to make sure that what ever I do this time, I make sure it's done right. So I will have to ask for specific things to make sure that they are done.
I really feel like the advice I'm getting is going to really help.
follow the advice given and you will be okay.
If you repair it, make sure it gets a filter dryer in both lines to protect the compressor.
I would not use your last a/c guy, get someone that is recommended to you.
I think everyone is trying to say, in a nice way... lose the old repair guy! Also, I can tell you that surges in electricity DOES blow heatpumps around here, regularly. My brother is an HVAC guy, and you can get a Rudd or Carrier unit to last WAY over the life expectancy. I put a new Rudd on the house after the same deal you are going through. The installer was watched like a hawk, and we had to "straighten him out" several times during installation. Like, not evacuating the system. He was blowing the lines out with air, tried not installing filters on the old lines (a no no), and other stuff I don't remember. I was not confident with this guy at all. THREE DAYS LATER the system blew the circut board! Next the compressor failed!! I was livid!! I got in touch with a different company that sells Rudd, and the whole deal was done over, with Rudd picking up the tab. My point is, to follow the advise given here, and you'll be good to go. But lose that last installer! jimsjinx
Monkey with a Football
I agree with Jim about the south being electrically hard on systems. I'm running a large Trane XL1200 and it has been flawless for around 17 years (if I recollect correctly). It has been through hell here. 1 tornado, many brownouts and blackouts, house hit by lightening once that set the workbench on fire and many near hits. The one thing I have done is every year, get the coils cleaned and the system service checked and charged if needed.
Besides it being a large Trane system, this is what I attribute to it's long life and exceptional service.
Keep the load off of that compressor, make sure the environment it cools gets cool in a reasonable amount of time and always use an intelligent thermostat so the thing never has to try to start the compressor under an existing pressure load.
If the hot side of the freon isn't being cooled properly then your days are numbered.
Forum Diplomat
Can't help you, pardner, don't know enough...... man, it does sound complicated. Red and I are lucky and live in a relative temperate zone. When we remodeled our little house, it had an old wood stove, aluminum framed windows from about 1950, and no air conditioner....... I considered a ducted central system, but the costs were prohibitive for a divorced school teacher, and the house to small to justify it. Since free firewood was getting scarce, I went for a free-standing gas fireplace, and installed ceiling fans in every room! I also replaced all the windows with vinyl framed thermal units. The gas fireplace/heater and the circulating air kept us cozy.... we have since installed another gas fireplace/heater in our dining room, for an emergency backup and ambience (gad, I love that word!). Air conditioning isn't the great need up here that it is there..... and so we make do with $200 window units, which we replace every other year or so.....works for us!
The key is keep it small and do it all!
Cousin Jack said keep it small and do it all. Now that is my way for sure. :action:
Discussion Starter #16
I hear you loud and clear.:)
I had a Carrier guy out here today to give me an estimate.
First of all if I go with a carrier, I'm going to be spending a lot more money, at least with this guy.He's particular about a lot of stuff. I almost felt like my house wasn't good enough for a Carrier....;).
Actually he pointed outsome good stuff to me and made a couple suggestions for me that will help me out. For example when we installed the current unit, it was a real challenge to get the air handler into the attic. Theopening in the ceilingwasn't big enough becausethe piece of roofit's under is too close, so as the air handler cabnet went up the hole we had to lay it over right away and couldn't. We had to remove a2x4and push the drywall ceiling to it's limits. I mentioned it to him and he took a good look and noticed that it wasn't actually a piece of the roof but an extension of plywood sheething from another section of theroof. Easy to cut away and we would have all the room we needed.Sometimes its nice to have an extra set of eyes.
Lets see if I can get a couple more quotes before I decide what to do.
Thank you all for your help.
1 - 16 of 16 Posts
