1 - 20 of 41 Posts
i am here to ask a dumb question but i need to know. this is my first time with heel toe shifter and am not to sure about it. after riding for over 35 years i dont know if i need to change now. but how are you gonig to shift without it if you have floorboards that are in the way? please help 86 1200 aspy.
I think that a heel/toe shifter is on of the best things that you can put on a 1200.
It might take you some time to get used to it, but I think that it's worth it.
Paul
Im pretty sure with floor boards youneed to have a heal/toe shifter. Maybe there is a setup that does not need it but i dunno.Personally i hated that setup and went back to stock pegs.
Pat
Hi Blue Wing and welcome to the best GoldWing forum on the Internet. In regards to the h/t shifter, I know of no way to shift without one if you have the floorboards. On a GoldWing it takes a little getting used to but once you do, they are great.
I vote for Pat, took them off my 1200 and the 1100. H&T shifter just doesn't give the feel, I like real quiet fast shifts and the original shifter does that better.
ACTUALLY you can shift a Wing with just floorboards... Had the pivot bolt (shoulder bolt for the techies :dude:) break on me yesterday 12 miles from home (but STILL in Tucson). Soft toe shoes (leather Red Wings) allowed me to "just" get the front of the shoe under the shifter so I could up-shift. Down shifting was great, the height of the shifter was perfect to press down on it from the floorboard. YES, I do know I should be wearing boots, unfortunately I'm still looking for a set of boots that fit the "peg leg" on the right side.
Put the old peg and non-floorboard heel & toe shifter on, Short trip to ACE hardware for a new shoulder bolt, cobalt drill bit, (hardend shoulder bolt), a little time drilling out the end of the old shoulder bolt and then put the left board back on.
Yes I ride the wing with one "real" leg... You'll have to take the other one and my left arm to get me to stop riding
Been there, done that, left shoe has the scars to prove it. So don't tell me it can't be done.
BTW - The Wing is burgandy and I'm wearing Red Wing shoes... Funny how that works. :baffled:
Goldwing Addict :-)
blue wing. I can't answer your question for sure, but remembering what mine looked like with boards, I think you would need to do some mods to the shift lever to use it normallywith the boards, without the heel-toe shifter. Personally, I hated the boards. I got used to the heel-toe shifter pretty fast, but there were other more major issues with the boards in my opinion, so I got rid of them and got some original pegs. I am much happier with the pegs. Therewas a lively discussion about this on another thread if you are interested, but it seems that people either love the boards or hate them, with not much in-between. :) Here's the link to the other thread.
http://www.goldwingfacts.com/forums/view_topic.php?id=5522&forum_id=4&highlight=board
I think the boards are dangerous ,if you are doing a lot of travelling in town/traffic ,,,Your reaction time is slowed down ,because you have to lift your foot on to the brake pedal or drive with your foot up on the brake pedal ,,I took them off a 1500 I had a few years ago ,,Might be alright for long runs ,but around town dangerous ..My opinion for what it is worth ..Ciaran
Paul ,, speaking of shifting, I had my bike out the other day for just the second time since i got it. was riding around the neighborhood to get more use to it . I did alot of stop and go at the stop signs. Question is that sometimes when i down shift to first gear coming up to the stop sign I had trouble getting it to go into 1st. I had to kick it hard then other times it just sliped right in . If I got to the stop sign and hadnt got it into 1st yet i would sort of let the clutch out and i must have been in netural althoght the light was not on but then when kicked it the netural light would come on and then i would push it down to 1st. This is my 86aspy , Just wondering it this is normal or is it because i am a novice at riding .. thanks Larry
This is my first experience with H/T and Boards and I never will be without them again. Ciaran's point is well taken, but I disagree. I usually shift my right heel up off the board and on to the stationary rear peg of my brake lever when in town. I do not believe that a significant lag is present.
As for precision of shifting, I simply do not find a problem.
Speaking of pegs, you all know I am an OLD trials rider.......LOLOL!! This Christmas in Arizona I had the opportunity to ride a bike of one of my son in laws mates. A Montessa Scorpa (Not sure of the dispalcement). Now that is riding the PEGS!!
Lovely bike though and so well balanced, I would love to compete today. My old Bultaco Sherpa though, would be outclassed.
I soon discovered the following:
1. I need to lose kilos
2. More so, I need to lose years!
I strongly suspect I would be outclassed as well. I did get to show the Scorpa's owner, Randy, a trick to "Charge" the fork for lift. (I suspect though he may have been humouring the old man)
When I got my 'Wing in October, it had floorboards and a heel and toe shifter. Though I thought they looked good on the bike, I wasn't too crazy about how well they worked. It seemed as though I had to struggle to get the bike to shift up or down at times.
After closer examination, I realized that the shifter wasn't adjusted properly. After getting it adjusted correctly, I've found that the shifting is perfect now, and since there's an entire floorboard to work with, finding different positions for your feet while moving is quite easy. Plus, you don't have to worry about scuffing the top of your left shoe when putting your toe under the shifter. The one downside is that they will scrape when cornering hard, but I think of that as a limiting factor, which is probably a good thing.
Larry , like Scott says "After closer examination, I realized that the shifter wasn't adjusted properly. After getting it adjusted correctly, I've found that the shifting is perfect"
You might need to modify or adjustit a little, I think that you are running out of travel and the upper part of the h/t shifter where it contacts the bike's shift lever needs to be a little lower.
Paul
I eventually got used to the Heel/Toe shifter on my 1100 but I thought the floorboards were dangerous. I had to take it easy in the corners or the floorboards would drag. I did find one up side to the floorboards; on one occasion when I neglected to put down my kickstand they stopped the bike from going too far over and was easy to upright, no one even noticed I dropped it.
Discussion Starter #14
hey thanks for yopur reply i quess its a personal thing. ill keep riding and see what happends.thanks my bike is 2-tone blue also.thanks jluvs2dive
Welcome to the Forum Blue Wing:waving: :waving: I have had them and did not like them and changed to pegs. For me, they were a safety hazzard. You are right, it is a personal thing.
I don't think they are dangerous. Your reaction time getting your foot to the brake pedal is probably still faster than or the same as getting your foot on the brake pedal of a car. Plus, you're probably already braking with the front brake which gives you most of your stopping power anyway.
I had floorboards on my GL1200 and also had a right peg.
I put floor boards on my GL1000. Absolutely hated the heel toe shifter. First few weeks I could not stand them and thought about taking fllorboards off so i could shift normally.
Glad I waited. I love them now. After I have gotten used to it, i would not go back.
Took a while to get used to it, but once you do, you will love it.
One thing to keep in mind as well is the fact floorboard mounts crack and break overtime without you even knowing it. When I decided to put thepegs back on mine, I was shocked when I removed the floorboards. The brackets and braces came off in pieces... Made me think of what could have happened going down the road.
Any of you guys with floorboards ever stand on them?
1 - 20 of 41 Posts
