Hello and Welcome Ben . I cant say if the carb mix will creat a problem for you . Perhaps we can have a Moderator move this to the Technical forum . there it will have alot more exposure .
Great. Now you'll be driving in circles......:sadguy:it's gonna be running rich on the two cylinders with the 771a carbs. Bigger jets in those I found out
As the mechneck put them on opposite sides it would run like an Army bike "Left, Right, Left,Right...ETC."Great. Now you'll be driving in circles......:sadguy:
No jets in Randakks kits. The old ones are reused.Hay back up and think about this!you bought the same kits for all carbs right?so the jetting is the same , the only DIF. could be the MM.bore of the carbs.that could diff.
