1 - 9 of 9 Posts
First i like to thank everyone on the carb info and i got them right, but ...........
now the bike will only fire on the rear plugs if you hold the starter button,when you let it go it drops the 2 rear cly spark
iam lossing my hair over this bike.
someone have a idea what its doing and where to start:gunhead::gunhead::gunhead:
It sounds like the wires to the coils are wrong and the coil for 3 and 4 is being powered through the resistor only. (I'm having a brain fart on the proper name for the resistor).
Ballast resistor?
Check voltage to both coils with the engine running, black/white wires.
Could be the coil for the 1/2 plugs or the wire that feeds that coil.
1 - 9 of 9 Posts
