Help GL1200! I need a little instruction or advice
617 Views 3 Replies 2 Participants Last post by  DaveO430
Well it has been about six weeks ago that I bought this 1984 Aspencade 1200 that was in excellent condition only to find out it had a leaking head gasket. Head gasket has been replaced along with new belts, thermostat, fuel filter, oil and filter. Going to replace radiator cap, air filter, new coolant, and new radiator hose. My questions are,
1- is there something to put on the coolant drain plug to make it easier to remove next time?
2- do I use some sort of sealant on the radiator hose when I reinstall?
3- I also flushed the radiator with Prestone radiator flush because the temp was eight bars. I noticed when flushing with distilled water and the cap was off that water would push out the top. Is this because I maybe put in to much water. I want to get this right so when I go to put in new coolant I don't end up wasting a lot. Is this what is called burping? By the way temp is six bars now with extended idiling and the fan comes on also at six bars. Fan had a blown fuse for some reason but is working good now. Fuse was located under the seat on left side. Bike has 25,000 miles on it
4-Can someone supply part number for replacement radiator cap? Would something work from Napa Auto or some other supplier?
5-Is twenty to thirty minutes enough cooling time between distilled water flushes?
Don't want to crack a head.
Thanks in advance to anyone that can help out an old dude that ain't so sharp anymore.
Oldmanonavtx
1- there should be an aluminum washer on the plug. If it is missing the plug will be hard to remove.
2- You don't need sealant on hoses.
3- The overflowing of water is normal with the radiator cap off. Just make sure you run it long enough when filling with coolant to get all the air out. Leave it a little below the top so it doesn't overflow until the air is out then fill it to the top and fill the reservoir.
4- Radiator cap part # is in the goldwing tips section.
5- Yes 20-30 minutes is plent of cool down time.
In the tips section it list radiator cap part #10229 for a 1100. Does the 1200 use the same?
oldmanona vtx
I didn't realize the 1200 was not listed but I think it is the same.
