Are you sure the starter is the issue? Not sure of your abilities but there are a dozen different things that can cause the starter not to work. What have you checked so far?
Like, what makes you sure the starter is bad? There are many things that can cause the starter to not work from a bad battery to a blown fuse. There are relays and switches and various other things involved, the starting circuit is complicated.
On starter relays A and B all 4 stud (large) terminals should have 12 volts with the key on, in neutral, kill switch on and start button held down continuously. In other words the bike must be configured to start and the start button held down. Then measure voltage at all 4 large terminals on the relays for 12 volts. Starters rarely fail.
98' GL1500 SE continues to Crank Over with th key in the Off position!
I tried to start my bike a week ago and the battery was stone dead- i discovered that the key had been left on in the first click position. ok no biggie right? I hooked up the battery charger for a few hours. It started...
Purchased an 84' goldwing for $50, seller said it ran good but he also decided to cut every wire hose and oil line. Just trying to get the engine running but the wiring diagram is overwhelming anyone have any advice on just getting the engine running.
I have a 1998 Honda Goldwing SE. I parked the bike about 1 month ago and was starting great. Tried to start today and will turn over and not fire. I have with a good battery. kill switch is in right position, all fuses are good, Reverse switch lights work. I pull one of the plug wires and no...
