03 gl1800. I'm finding whenever I work on the bike that the po left off or lost some nuts or screws.
Yesterday I went to install a belly pan. There are two 10mm nuts on each side lower panel, under the shift lever and brake pedal, that need to be loosened to install this. Well, there was one missing on each side. I want to order some replacement nuts, with the appropriate washers because they are missing as well.
I have looked on bike bandit and hdl parts online, but I cannot find that particular part. I don't know what that cover would be called. It is below the brake and below the shift lever as I said. A 10mm socket fits the ones that are there, so I assume I could just get a couple 10mm nuts? 6mm nuts? but I'd like to find the right ones. Any help out there?
