Hi please can someone urgently assist me. I have a 2005gl 1800 and am out of town stuck. I put the bike into reverse gear then reversed and switched off the motor. I can't get it out and am stuck. If anyone can help it will be much appreciated.
Colin wagner
South africa
Senior Guru
Have you tried rocking it out of gear Colin? Ignition on, rock back and forth? Is the reverse switch stuck ON? That happens too, stupid switches on the 1800 I think Honda went backwards on quality control there.
Thanks guys all sorted. Left it for an hour made sure the reverse button was on, turned on the key and R light came on then put it in Neutral. Thank you again
Regards
Colin
