My foot has oil on it when I go out for a ride and have traced the leakto the Seal on the Foot Shifter. I purchased a new seal from my local Honda dealed but when I asked how to replaced it he said he did not know how to that I may have to split the case. There must be a way to pull it out with out spliting the case . Not much room for a seal puller to get into the area.
Any one have some Ideas or has anyone already replaced this seal could tell me how .
Thanks.
Sonnyboy
1981 GL1100I only 30,220 miles
I also had a fewwater dropfrom the weep hole a couple of times but it has now stoped after I replaces the thermostat and hoses, should I worry about this?
Disfunctional Nimatode
Hi Sonny...........that seal around the shifter shaft will come out. Just dig it out after removing the shift lever. You may be able to drive a screw into it and pull it out with the screw and pliers. Just push the new one in with a socket.
The water from the weep hole is a sign of failure of the o ring around the water pump,(the larger of the 2).... or the water pump itself. I would plan on replacing the whole pump and all orings and gaskets effected by the replacement job. This will require the front engine cover removal.
Hello Dancinbear and thanks for the reply.
I had planed to try and pull it out but the screw sound like a plan, thanks again for the help.
Sonny
02 GL1800 w/Auto Pilot
You might also use a right angled pick to pull it out.
I have an ice pick that I bent the end of it with pliers for digging things like that out of recesses.
