1 - 9 of 9 Posts
I just got a set of used saddlebag lights that replace the reflectors. Where do the wires hook up? Do I need to drill a hole for the wiring? Thanks!!
Piled Higher and Deeper
I think most people do....however, I was able to run the wires directly into the space in front of the rear corner light without drilling holes... I did use a soldering iron to form a groove in the back of the side light black plastic backing so the lights would mount flush with the bag lid..
Guru
can you post a pic of what you have & where you want to put it???
These are just exact replacement only with bulbs in them. They fit the 'track' of stock reflectors. thanks. These have male plugs (2 wires) on them, but I don't find stock female receptors.
Monkey with a Football
They plug in inside the lower rear corner covers just under the rear box tail lights.
It is normal to make a hole for the wiring but if the plug is already on, you might be better off to make a slot like SDB did.
I drilled a hole for mine and spliced the wires. I cable tied the wire to the hinge so it won't get snagged on the lid.
They are not plug and play. They connect to the "brown" tail light and "green" ground wires for the tail lights on the saddlebags.
Discussion Starter · #8 ·
thanks all. I must've gotten a bad set. They don't light up when running with tail lamps.
Any chance you got a set of the Hondaline saddlebag lights. They did not have bulbs, rather the electroluminescence type lights. They had "bullet type" connectors on the wires and connected to an inverter box that came with them. Then the inverter box was plug and play to the bikes wiring. I have this type on my '99 Wing.
1 - 9 of 9 Posts
