I messed up on my 08. I removed the rear caliper mount bolt (on top of caliper) and
cross threaded the bolt. Anyone know the thread size of the hole so i can
tap from the back and fix thread? Where can I get a new bolt? All internet
sites that have diagram do not have a part number for the bolt.
The bolt can be gotten from your local Honda shop. Then you can take it to a higher end hardware store and they should be able to match the threads with a tap.
Or you can drill it out and tap it for a bigger bolt.
I would do the former. Many would do the latter.
Should be 10x1.25. Will check tomorrow if I think of it.
