Without a regulator in the circuit, the charging system will go full tilt. Check your charging system voltage at the battery. You'll probably find in excess of 16 volts. DO NOT run it this way. It'll kill your battery and burnout your bulbs...
I don't know. I've never ridden one with the voltage that high. It's a twelve volt system. 16+ volts isn't going to do it any good. If it were mine, I'd trailer it or replace the regulator.Will it effect the ignition If I ride it to the shop ?
Well I did and the only damage was to the new battery.I don't know. I've never ridden one with the voltage that high. It's a twelve volt system. 16+ volts isn't going to do it any good. If it were mine, I'd trailer it or replace the regulator.
He has a '76 Ken. Possibly still has point ignition system.Well I did and the only damage was to the new battery.
I doubt a ride down to the dealer would cause any more damage as he's already been riding it this way.He has a '76 Ken. Possibly still has point ignition system.
