Senior Memory
What is this all about? I have a small module(#2 in the photo)that isnt in the shop manual and the blue wire(#3 in the photo)is going to that module. In the manual the blue wire goes to the fuel pump connector (#1 in the photo). Any Ideas what this modification does? Note I am postin the manual diagram in the next post, see below.
Maybe a noise filter for the CB or stereo. Someone should be along shortly that can positivity identify it.
I take it the gauge works. #2 almost looks like a relay of some kind, but have no idea why it would be there. No doubt somebody has added something to the system. I wonder if they didn't put a different sending unit into the tank.
Interesting.
Senior Guru
hi fireman its the noise filter for the cb to stop you hereing the pump runing
Senior Memory
Interesting.
Yea, the fuel gauge works and I am not sure about my fuel light as I have not run it that low yet. I guess as long as it works it doesnt really matter, just curious if I was being tracked by Aliens or something!:cheeky1:
Senior Memory
You sound pretty sure about that so I will go with a noise suppressor! Thanks. I still dont understand why a wire is no longer attached to the #1 terminal on the fuel tank module. Maybe that fuel light wont work when I get too low!:hovering::alco:
