I removed the front fairing on my 2001 to replace a broke lens .no easy task ...is there a trick on getting it back together? seems to be hanging up somewhere
· Still Learning
You removed the front fairing to replace a lens????
You need more explanation in your post.
What lens are you referring to, why whole front fairing off, what part of installation process is the problem?
"Trick to put it back on? "
Not enough info given = misguided answers.
The part was the hedlight lens to access the whole front fairing has to be removed ..even Freds maintenance cds ..which I have... don't fenture into this area .... esentally part of the dash.. windshield and the whole front top fairing came off leaving the front completely naked what I didn't realize till it was to late was you can just remove one side.. anyway after a day of struggling I finally got all the holes to line up and with much push and pull and the help of some clamps ... it's back together
thanks for listening
