Assuming the SmartModule is still functioning (and we've never had one not function)...
If the unit NEVER flashes then you either have a bad connection in the LED circuit or you don't have power going to the Smart Module (or the SmartModule failed).
My best guess is that either an LED wire got broken as Mike mentioned or you have one of the two LED connectors come loose on you (newer units have two connectors, one at the module and one 10" from the LED).
If you find a broken wire at the base of the LED itself, do not attempt to repair it. No one so far has done that correctly and successfully and you have a chance of blowing the SmartModule driver if done incorrectly. Let me know if that is the problem and I'll get another one coming your way.
I would start by pulling the seat and check the connections. Occasionally someone has a module positioned so that the seat presses down on the module connectors when they sit on it and that can cause a disconnect.
If that isn't the problem, simply unplug everything but the power and the LED. With the key off you should get one flash every 5 seconds, with the key on you should see the 1st gear blink on the Gearhead model or rapid flash on the Traveler model.
If that doesn't work, then use a voltmeter to verify that the outer pins of the power connector both have over 10 volts on them when they key is on (the center pin is ground). If not, check the SmartLight 5 amp fuse on the power harness and the 5 amp fuse in the aux power circuit in the Honda fuse box.
If you do have voltage on both outer pins of the power connector, then it is either the LED, the connection to the LED or the LED driver in the SmartModule but as already mentioned, the latter would be super rare.
Post back and give some results and I'll tag this thread to notify me.
I'm good till 8pm eastern tonight and then again in the morning.
