hello , to all. im new to the forum, but i thought that who better to get help from than a brother goldwinger. so here it goes i have a 83 gl1100 and im trying to hook up the trailer to it. i have a box that somebody gave me for wiring it has a red wire not sure how to do this or were this goes help!
under the seat is the main wiring harness for the brake and turn lamps i would connect to those and do it that way put a trailer plug to connect you could run another fuse box but if your only going to run 2 lights on the trailer i wouldnt bother with it
Can you give a more detailed description of the "box". It may be a trailer isolator which you need unless you have LED trailer lights.
