Guys,
Had to pull the starter out to push the rubber shaft boot back on. Bike started up ok and I even drive it a few miles. Went to put it in reverse and the bike did not move. Put it in gear and back in neutral a couple of times and it engaged reverse after hitting the switch. Now it is stuck in reverse. Can not start. Bike will not move. "R" flashes. I can not disengage and I can not start. Check all fuses and the are good. Any ideas would be greatly appreciated.
Thanks,
Herb
Guys,
Thanks,
Herb
