Here are the total instructions that you get when you buy one of these units.
Orange wire to left turn signal light
Light Blue wire to right turn signal light
Blue wire to the highlight Indictor
Blue/White wire to the water temperature sensor
Yellow/White wire to the oil float sensor
Black/Yellow "Wire to the engine pulse,
or the positive of the Ignition coil"
Red "wire to the power positive, before the ignition switch
Or directly wire on the positive of the battery.
Make sure the power always on"
Green wire to the power negative
Black "Wire to the ignition switch positive
or the oil gauge 12V positive"
Green/Yellow Wire to the brake (either handle bar switch or the foot brake switch)
1 The left button is turn of the single mile and total mile.
2. The right button is the turn or oil volume and the water temperature.
3. When you want to set the time, please press the left button first, when you see the screen shows "odo", then keep press the right one about 5 seconds. Then you will see the set part sparkly. And then the left button can choose the hour and minute and the right button can set the time. Then press the right button again for 5 second. The the time set is complete.
- hercolor
Here are some pics of the installation so far.
This pic shows the wiring mess. The relay you can see is for the neutral light. The 9 pin connector just below the relay is the connector that the original dash plugged into. I have a mating connector on it to patch across to the new unit. The white 9 pin connector to the right is the connector on the end of the new unit's wiring harness. It is a perfect match for the original 9 pin connector for the original dashboard. I was lucky enough to find a couple matching 9 pin connectors at a junk shop down the street. It sure made things easier. The wire colors don't match, but it isn't hard to figure out what is going where.
This next pic shows how I have it mounted.
Next shows the Red "P" and the High Beam indicator.
The next one shows the left turn signal and "neutral" light.
This one shows the "neutral" light and right turn indicator.
Ok, I now have a speedometer! I made the bracket for the sensor, mounted the magnetized bolt and it works. At least it works up to about 6 mph. That's what I got out of it spinning the front wheel.
Friday, I'll get the rest of the bike put back together and take it for a ride. My next project is to install a Rostra cruise control. I won't be able to work on it tomorrow, Wed, and Thur. I work tomorrow, and immediately after work I'm going to Rogers, AR to dog sit/house sit for my brother while he gets some medical stuff done in Little Rock. Then I work again Thursday.
If anyone has any questions on this setup feel free to ask. It was easier than I originally thought it would be.
- hercolor
