21 - 25 of 25 Posts
i hit it in with a splitting ax and then hit it good but it kept blowing the screw driver out and wasted the threads
Discussion Starter #23
Thats why I used the cross meathod with a punch. tap punch in really snug then snug bolt to bearing and then tap punch into bolt a little more and you should be able to pop the bearing right out.
Ride Safe, Ray:waving:
thanks for the great advice and all .. the rear wheel is on and turning ,all systems are go 3...2...1...
Discussion Starter #25
Great News glad you got it going:clapper::clapper:now you did clean and inspect that drive flange and re lube it with moly60 while you had the rear tire off didn't you:baffled:
21 - 25 of 25 Posts
