On car tires, there is a delicate balance between weight on the tire and pressure in the tire. I can tell at a glance if a car tire has been run over/under inflated, just by the wear pattern on the face. Overinflated tires tend to be worn more in the center, while underinflated ones tend to be worn at the edges.
While a motorcycle tire is more rounded than a car tire(darkside excluded), the same theory still applies. A tire that is inflated to the max and is not loaded to the max., will be running on a narrower surface, and that surface will wear faster than if the tire was pressured correctly for the weight it carries. My elite III front tire is rated at 600 lbs at a max pressure of 41psi. But that tire never comes close to carrying 600 lbs., so therefore, why should it beinflated to 41 psi??
I have taken a lot of what has been said to heart, and I compromise a little. Honda says 31 psi(probably for about 350 lbs on the tire, and giving a smoother ride)Dunlop say 41 psi for max wt. of 600 lbs. I use about 36psi., and so far, the tire is wearing just fine.
