1 - 20 of 110 Posts
Hi I recently bought my first Honda goldwing and it has no spark....could you please tell me where the ECU is located thanks in advance..
1st of all, since our forum currently does not show your profile, what model and year bike are you talking about?
and, what things have you done so far to try and diagnose it?
The title says he has an '85 Ltd Edition...
No spark is usually an easy fix. Please give us a bit more information though, have you checked the battery voltage yet, , , the '85 doesn't need as much "juice" as the 1500's do, but your battery is still very important to fire the coils. Fresh gas, clean air filter and a strong battery will usually solve the problem.
Hi john I recently purchased a Honda goldwing 1985 1200cc limited edition...I have checked if there is power to the coils...now I want to locate the ECU to see if there is any faults showing on it ...
The
The battery is good new air filter ....
Magic Moderator
This is the chart for the LED lights on the ECU. You'll find the ECU under the trunk, you have to bend and look under. The lights are on the left side when seated on the bike.
320733
Hi john I recently purchased a Honda Goldwing 1985 1200cc limited edition...I have checked if there is power to the coils...now I want to locate the ECU to see if there is any faults showing on it ...
Doc,
I apologize, we are using Brand New forum software, and when I clicked on your post, it took me direct to the post and we don't see the title of the thread :(
We will have to train our memory cells to remember what the thread is, or back up the page so we can see the title :(
meanwhile, more astute forum members have glomed onto your problem and are helping you out.
I edited your Profile so that your bike model now shows up IF folks will click on your Username and then click on ABOUT.
Discussion Starter #10
Could someone please post the list
This is the chart for the LED lights on the ECU. You'll find the ECU under the trunk, you have to bend and look under. The lights are on the left side when seated on the bike. View attachment 320733
Thank you so much I wont get a chance to look until tomorrow... I'll keep you updated
Doc,
Thanks john 😀 trike lady has being very helpful...this site is amazing 😀😀
Trike lady I dont know how to thank you your amazing 😀😀
Welcome to the forum. Do you have an OEM service manual for the bike?
No unfortunately I dont !!!! I only got the motorcycle two days ago
Hi Denis and bike I have no one service manual as I only have the bike two days !!!!
Doc,
click on your Avatar up in the top right corner, notice the new Red Dot?
That means you have a PM or Private Message, or "Conversation" as this new forum call it :(
I sent you a link to a manual there.
Discussion Starter #12
Doc,
The ecu came up with a pbr/pbl fault I ordered a second hand part off ebay I hope it works !!!
Try this. for grins?
I just restored a SEi (Same electrical system)
I get a no power/start evey other time I lifted the Nav computer and without realizing it. "Touched/pushed" on the right harness connector coming out of the fuse box.
There are three connectors. Left/center/right when looking at them with the Nav lid lifted.
I had a bad connection in the Right connector.
I could move the wires and watch the dash go nuts (on/off/flickering)
I cleaned up both ends of the connector (Electrical contact cleaner)
After cleaning/lubing the connector.
I couldn't disrupt the connections.
Something for you to rule out,seeing you just bought the bike.
I chased quite a few gremlins before I got it sorted!
Keep at it. you'll be rewarded in the end with a great bike. 😎
Doc,
It appears the sensors you are referring to measure intake manifold pressure and would not have any affect on spark. How sure are you that the issue is in fact spark? Are you sure enough to hold on the wire while you try to start the bike? If you have a fault code for both sensors I would suspect you either have a wiring issue or you have a large vacuum leak. I also wonder if you were checking compression and that set the code? If you have all the plugs out and spinning the engine with the starter the ECU will see no vacuum as there is none with the plugs out. This could set the Pb code?
Doc,
Right, it is highly unlikely that both sensors are bad and they won't prevent it from having spark, or starting even for that matter. They would just make it run bad, way too rich most likely.
Discussion Starter #16
Doc,
Thank you I will try Monday !!!!
Discussion Starter #17
Doc,
I definitely have no spark.... the plugs were in .. the 0 was flashing and w was lit up on the ecu....
Was that the only flash code you got? That is for the right sensor only. The left would flash 1 and the w solid. Did you get both as an earlier post said PBR (right) and PBL. (Left)?
1 - 20 of 110 Posts
