Honda goldwing questions
585 Views 2 Replies 3 Participants Last post by  gled02
1. How do you tell if you have a keyless remote trunk on your goldwing you just bought and have no remote?
2. Shortly after i had honda bleed my clutch it started to creep with it in gear and cluch in. Creeps a little then stops. I had honda do it because i had the same trouble when i did it. The trike has 30000 miles on it. After you bleed the clutch it works fine for awhile and then goes back to the same thing. Shifts fine but you have that clunk when you shift in to 1st from neutral. Let me know what you think.
1 - 3 of 3 Posts
It would help if you told us what model Goldwing you have. Required information I would say. Welcome to the forum.
If it is an 1800 (2001 to 2012), it has a keyless remote function. If it is any of the earlier years, it does not.
Again, if it is an 1800, the clutch lever is adjustable for travel, and may be set too low.
Let us know what year Wing it is and we can be of more help.
1 - 3 of 3 Posts
