1 - 3 of 3 Posts
Hope someone can help I need a fitting template for the hondaline CD player to drill the 22mm holes for the mounting brackets. Or at least the measurements from the centre of the gromet hole. Thank-you
They seem to be hard to come by and I haven't seen any available on the 1800 forums. People just throw the templates away and never think they will be needed again. I hope someone can help you.
Thank-you Ron for your reply. I looked and pondered and thought and was none the wiser. I looked some more and sat the CD holder in the trunk and marked it where I thought it should sit. Drilled pilot holes from the inside of the Trunk then cut the holes from underneath and it worked CD fitted. Now just have to work out how to fit the rear speakers?
1 - 3 of 3 Posts
