I wired mine the same way. I did find out that when the meter is reading 13.5 volts, the actual voltage at the battery is 14.5 volts. So anything over 13 volts on the meter is ok....-RichI have a Volt meter.. I hooked it up to the accessory terminal in the fuse box and to ground.. That way it goes off and on with the switch..The reading is off slightly.. I took a reading at the battery and make the deduction from the reading I get at the Volt meter.. It's worked on 2 bikes I've had..
If you go the volt meter route, look for one with 3 wires.We put a new alternator in my friends 1500 and now were trying to install a amp gauge to check the output,but don"t have any idea where to wire it in. Thanks!!! :? Or a Volt Meter would Probably be Better!
Has this one gotten soaked? There have been a lot of posts that they die once wet.I use this...
http://cyclemax.com/inc/sdetail/digital_5_function_voltmeter/129/342
Here it is on my bike... This was the only place I could think of that doesn't require cutting into something, is unobtrusive yet easily readable, and 'fits' on the bike so it looks like it belongs there...
This one also montiors the the line voltage, as well as battery voltage.
Hasn't gotten really wet yet... but I DO ride in the rain.... It is mostly protected by the windshield I guess...Has this one gotten soaked? There have been a lot of posts that they die once wet.
