I looked all over for a small switch I could use for a starter. I found micro switches at Radio Shack. I did find them to fit perfectly. Fit and function are not the same. I couldn't turn the headlight off If connected the power full time. If not connected to power, headlight wouldn't work at all.
By using one of the micro switches for horn should be acceptable. They look great on the stock brackets and come in a 4 pack (two red buttons and two black buttons). The down side is that they are extremely heat sensitive. No matter how I tried, I found it quite impossible to solder the wires to the contacts. I believe somewhere I saw some micro blade connectors that could be plugged onto the contacts.
This is not a solution but rather something else that might be usable. They didn't work for me, I kept melting them. I just gave up and purchased a stock used set of switches.
Terry
