RaMai,Im not sure I could do it without taking mine back off but here is a rundown on how I did it;first I took a small board(3/8) thick and cut it abuot the size of the opening on the switch,then I took a file and shaped it slightly smaller than the dimention of the button opening(you can use thestarter button for a template),I then used a drill bit that was as close to the size of the button stub,drilled down accordingly untill it fit snug.It was then I painted it black,epoxied the drilled hole and pushed it on. It has been working fine ever since,and you cant tell it from a stock one.Moon.
