At the suggestion of a member I took a closer look at this wire. It appears to have been running hot. I have done the fix on the wires coming off the stator (solder the three yellow wires together) So I am not sure if this other wire is showing signs of heat from before I did that fix or not.
The question I have is what can I do to make sure these wires don't cause a problem.
I had some connectors look like that one time and i thought they were getting hot also, but it turned out they just had a bad connection and were arcing and caused it to look like that.
Have you checked to see if it is hot to the touch, or does it just " look hot"?
Well I rode the bike just a little ( I am trying to fix another problem) and after riding for ten minutes the wires did seem to be a bit warmer than the others in that area.
If in doubt, solder it. Arcing occurs when there is a loose connection. The arcing also makes the connection dirty and a poor conductor. Eventually there will be a problem.
Keep hitting that double post key
Well, that's one way to build-up the post count.:cheeky1::cheeky1::cheeky1: :gunhead:
