Soldiering is easy, just takes some practice. Glad you found the issue so quickly and was able to motor on!
Yeah, wire nuts are called for.... I just never have the damn things around. Those windmills? We locally rejected them, but our erstwhile leftist governor of the time, Christine Gag-wire, overruled us and put em' up anyway.....I have those dumb sidestand and clutch nanny switches bypassed on all my bikes. I just used screw on wire connectors (wire nuts) and zip tied the wires to something. Never had one fail. When I worked on A/C I used wire nuts and crimp on connectors by the thousands. Never had one I installed fail. I solder if I need a really low resistance permanent connection.
I see a bunch of those awful electric windmills in the background. On my recent trip to Portland, on I-10 and I-5 I saw thousands of those things. Someday there will be millions.
There ya go! Sounds like a great solution, thank you friend!Mel, if you don't want learn to solder look into using "shrink/solder connectors".
They're a length of shrink tubing with a solder ring. You twist the wires together then slide on the connector and heat to shrink the connector and melt the solder into the joint in one step. You'll have a strong and waterproof connection.
To be honest I've never used one of those "shrink/solder connectors" but I do know you have to heat the wires to ge them hot enough for the solder to flow through. If you don't get the solder to flow through to all the wires, it isn't a good connection and could fail just like twisted wire.Mel, if you don't want learn to solder look into using "shrink/solder connectors".
So, that's Mount Olympus in the background, where the Goddess Christine lives?Those windmills? We locally rejected them, but our erstwhile leftist governor of the time, Christine Gag-wire, overruled us and put em' up anyway.....
My twist and tape lasted five years....the other is still going! Ah, well, as a mechanic or technician, I make a damn good ski patroller!I don't like twist and tape, it is a temporary solution to last maybe 1 or 2 days.
Wire nuts on the other hand can be almost permanent if installed correctly.
Mount Rainier......So, that's Mount Olympus in the background, where the Goddess Christine lives?
