1 - 3 of 3 Posts
I want to remove the instrument cluster and air controls shown in the attached picture so I can replace the handlebars and the fork springs on my 83 Aspencade. Maybe I missed it but I can't find the procedure for removing these. Any suggestions?
I think I was wrong once!
someone should be able to directly tell you soon but on the 86 aspincade I think you have to remove the windshild and headlight first.
You only have to remove the lower (trip) panel which is separate from the gauges, held on with a small screw on each side at the rear of the trip panel then you will have access to the handle bar clamps.
1 - 3 of 3 Posts
