Since the radio has output, I would say that the problem is in the antenna, splitter, or cable (not the radio) Since you can't seem to affect the results with length changes, I'd lean towards the cable or splitter.. but the coil in the mid section of the antenna could have a problem too..
Incidently, the power meter only reads correct power wihen it is hooked up to a proper load (50 ohms). A non working antenna or a high SWR is not a proper load...
