I was reading the posts from ‘PACE’ about the problems with his bike and saw a comment saying that a ‘leakdown test isn’t important and don’t bother with it.
I’m here to disagree and would like to relate something that happened to me and maybe it could help someone else.
These are the facts as they occurred to me first hand.
I worked at Spinetti’s Bike Shop in Jackson, Ca. We were authorized Honda, Suzuki and Kawasaki dealership.
This occurred in the 1990’s although I don’t remember the exact date. I had to work on a GL1200. The work order said that it ‘misses on 1 or more cylinders on acceleration and idles rough....
has been sitting, needs new battery.’ The RO also said ‘shop in Sac cleaned carbs and tune up- no help’
So I have to interpret what is needed so first thing is jump it with my test battery. There could be more than just needing a battery and I won’t charge him for a battery if that’s not the problem.
I get the engine to start and the RO is right ... runs rough at idle and a dry rev doesn’t sound that great. So first things first... compression test and leakdown test.
Honda has pounded those 2 tests into our brains at every Honda class I’ve been to.
So compression shows a little low on 3 cylinders and about 20 psi low on 1 cylinder. Not bad.., could be worse.
Leakdown shows 10% leakage on 2 cylinders and 70%+ leakage on 2 cylinders.
Needs new valves? I had the service manager contact the customer for authorization to tear down.
I know this is long but the point is the engine needed none of what had been done by the shop in Sacramento and he’d wasted his money.
I got the engine fixed and it purred like new.... because of the leakdown test.
This story is true!
This story is true!
