1 - 20 of 38 Posts
How to change gear spindle shaft oil seal.
Hi. I have found that left side of the engine is wet. After investigation I have understood that the spindle shaft oil seal is worn. Also nicks on the shaft are worn and it haв a free play. Below is an info, how to change this ill-starred oil seal.
1. Get the bike on the right side on the guard ( I have used a pieces of wood under the guards).
2. Uninstall left lower fairings (see the manual because I was lazy to make some photos)
8. Pull the exhaust down and forward. Now u should to unscrew the shaft bolt and disassembly it. In my case the shaft had looseness and a bit worn nicks. I decided to cut the clearance by disc cutter; therefore I would squeeze the shaft on the spindle shaft.
Discussion Starter #10
9. I have washed the engine and screwed the screw in oil seal, it is the most easy way, or u can pluck out it by screwdriver, as me :)
Discussion Starter #13
10. According to the part number the size of oil seal is 17x28x7, but in my GL1500 SE ’00 the spindle shaft has a 14x28x7 size, so, be attentive before buying the oil seal.
Great tutorial really appreciate all of you posts. Keep them coming. :clapper:
You know your way around a camera as well as you know your way around a Wing. Great pics too. :clapper:
Thank you for taking the time to do this lesson! I know I have that job waiting for me in the future. Mine is just starting to barely seep oil. Not a problem yet, but with all the crud down there, it's inevitable! Thanks again, nice job. jimsjinx
I layed the bike down on a carpet...removed the shifter and reached around the pipes to do the job...but ya need to work like a tedious surgeon with longer tools...but doable without messing with the nasty pipes...good pics and tutorial!!
Lost on this *****
I just stripped off most of my plastic today as I am beginning to do all the maintence on the ole girl. (97 Aspy) I discovered that my seal must be leaking(very little) because of the oily mess around it.
I'm not too fond of having to take the exhaust all down just to get to it. And then the frame is right smack in front of it also:gunhead::gunhead:. But I guess it's better to do it in my warm garage then to be out far from home and have it give out completely.
I think I'll give a try at it without removing the exhaust likegrambo did. Only,,, I have mine on the jack right now. So I won't be laying it on it's side like he did.
Thanks for posting the tutorial with pics. It does help for sure.
its much much easier with it on its side..to see and work on....unless you get it up high on a rack..you should be ok...spray it out real good with carb cleaner and use a sticky sealer when you pop it in...no burrs on splines also...if you cant manage it you can just pull down the headers... not remove completely for more room...but with the right longer tools you dont have to.
1 - 20 of 38 Posts
