Attila wrote:
Thanks guys great to be a part of this:cheeky1:...Anyways could the problem be a condenser?..Also when I was playing I found a large green wire (probably ground) just hanging there not connected to anything. I connected it to the coil bolt retainer but I think its aluminum, maybe I should place it else were. Also the wires are good from the points to the top connector (the connection block thing) I still need to ring the wires from that point to the coils. . Just wondering has anyone had any trouble with the connector block or bus located at the left side under the fake tank cover. What I could use would be some good pics or a good wiring diagram. I have a manual I bought the one with the green cover. It kind of stinks:baffled:, but hey it was writen a few years ago. Thanks guys.
Attila.
Attila, you could possibly have a condenser failure but you said -
tried swaping condenser leads still nothing
SO, unless you failed both condensers (highly unlikely) you probably have other problems.
On that green wire? You really need to identify what circuit it belongs to & where it goes to. There are some green wires in the ign circuit. If it was a power wire or primary wire you might have blown a fuse by grounding it.
Start at the coils & MAKE SURE you have
GOOD power to both with the ign switch turned on (if not find that problem). Then place a test light on each coils primary low side (that's the wire going to the points from each coil), then crank the engine & see if the test light flashes off & on as the engine is cranked (if not you have aproblem there).
If you have good power TO the coils & the points are grounding the coil pigtails when they close you have other problems- like bad plug wires, fouled spark plugs, open in the resistor caps, failed coil,???
Twisty
