Issue: All good. Shut off bike, restarted and appears to have lost 3 cyls at idle & low speed. Once past low speed, runs OK.
Thoughts: Bike has inhaled one of those #@%!&*& EMGO fuel filters. Probably along with all the crud it had collected before the filter broke off internally.
I'm thinking that there is a piece of something in a low speed jet in one carb.
The Plan:I am in the research phase now...
Once in the garage phase, I will pull the (reasonably new) air cleaner off & inspect the carb tops for any sign of obstruction. Then, inspect for vacuum line issues, then would like to DRAIN the carbs and see what flushes out.
The Question: I see from forum searches that there are carb drain lines. HOW/where do you drain the carbs?
Other suggestions?
1988 1500.
Other suggestions?
