Sponsored Editorial Content
OK, I know, checking a motorcycle’s tire pressure is super easy. All you do is take out your handy tire gauge and apply it correctly to the wheel’s valve stem. Well, yes…and no. Tire manufacturers recommend that you check your bike’s air pressure when the rubber is cold – meaning at ambient temperature. If you’ve ridden your bike in the last few hours or have parked it in the sun, where the tires can absorb heat, the pressure will read artificially high.
Yes, we know that racers often check tire pressure immediately after they leave the track, but they’re actually using the pressure rise they’re getting out of their tire as a barometer for estimating the tire’s temperature and whether they’re leaving potential traction on the table.
Street riders have different needs. First, the air pressure helps the tire carcass maintain the proper profile, making for predictable handling in the varied environments encountered out in the real world. Second, proper air pressure helps keep the tires from overheating and cooking the life out of the rubber compounds. (A quick FYI, race bikes typically run lower tire pressures than street tires.) Third, your bike will get better gas mileage and longer tire life with proper inflation. Finally, both over- and under-inflated tires are more prone to failure than those using the correct air pressure.
So, before you ride your bike, check the tires’ pressure with an accurate gauge. Also, if you need to move your bike to get the valve stem to an easier place to use the gauge, take advantage of the movement to examine the tire’s tread for any sharp pokie things (a technical term) that could – or may have already – cause(ed) a leak. If it turns out that your tires do need air, an inexpensive bicycle pump can take care of upping the pressure a couple pounds without you even breaking a sweat.
Read more about How To Properly Check Your Motorcycle’s Tire Pressure at Motorcycle.com.
Banned
My not-fun is accessing the 90 degree valve stems on the 94-1500 with most tire gauges.
Cant read the digital one due to angle, and it doesnt hold the number after disconnect
John- does the one you linked keep the number displayed- as in pic?
It states for 90 stems
As for the round gauge used in pic- I think that falls under artistic license/concept- use of device that gives the story without words
...free from the limits of reality...and may feature a sponsored product~
I like the right angle one in the pic. I'm thinking of ordering one to add to the collection.
Yes, the one I have holds the reading about 15 seconds or more
I can't see the reading when taking the TPI until it is removed. It is so fast, takes about 2 secondsto stabilize
I have one similar to yours John, it's a digital readout one as well. Works well...
TEKTON 5941 Digital Tire Gauge
