I understand the rear brake actuates both the rear caliper as well as a front caliper at a 70 rear : 30 front ratio. I'm having trouble finding good information on proper servicing.
-Do all GLs have split lines for the rear pedal?
-From what I've gathered, best practice for split lines is to bleed the line(s) farthest from the master cylinder first, and the nearest line(s) last. Is this true for the Goldwing's system as well?
-Does a reverse flush (injecting into bleeder valves) work on split lines?
Extra deets: 2000 (gen 4) GL1500 36k miles, sat for extended periods with prior owner. Rear/front line(s) has zero pressure, reservoir is clean and full, pedal does nothing, just looks pretty and flops around. Still more useful than my ex though, at least this is salvageable. Front hand brake works fine. Supposedly after sitting, Goldwing rear seals can dry up and allow air, and after bleeding will need to be re-bled later once they're lubed up again from use. I understand this is a common problem; Usually just needs bleed or flush, sometimes an unseated rear line can rub the rear tire and develop a hole (not my case), master cylinder goes bad (which still creates some pressure, mine does not), or slaves get dirty and leak or cause bad fluid & air (also still has some pressure). I read something very vague about a pin that can fall out involved in actuating the master cylinder - anyone know anything about this?
Any comments appreciated, thanks guys.
