1 - 20 of 54 Posts
2016 wing; how do u remove rear tire without removing seat handles plastics etc ? I’ve seen videos of laying bike on its side:surprise:but I’m not gonna do that?
Laying it down is by far the easiest but if you won't you can remove the rear panel and some other parts and take it out the back or if you have a motorcycle jack you can remove it from the bottom. Removing the seat handles? that wouldn't be any help.
02 GL1800 w/Auto Pilot
Why not?
the engine guards keep all of the plastics from touching the ground.
I put down a furniture pad from HF, doubled it up.
laid it over, and then put a jack under the center stand to push it up over even more.
Still had 2 inches of clearance from the mirrors and Side Wings to the pad.
makes for a 5 minute job to lay it down, 5 minutes to get the bolts off and slide the tire out.
the last time, I did w/o the pad, used an old pallet. After it was laid over on the pallet and that roller at the back, I slipped the floor jack under the center stand and raised it up more. oodles of room to make it easy on my back.
Nobody You Know
I had a rear tire so damaged it wouldn't hold air long enough to get to a tire shop to get it replaced. I did the "lay down" method on my garage floor, then found out the shop had to order a tire. Ended up leaving it on its side for 3 days until I could get the tire replaced. Looked sad, but no ill effects once I got it re-mounted and vertical again. That's when I discovered the tire guy had destroyed the TPMS sensor - but that's another story!
I did it on an 05 but know your 16 might be different but I just put it on the center stand, took off the rear panel and slid it out the back. Of course loosen the lugs before you do anything.
those of us that have trailer hitches make that impossible.
it has to drop out from the bottom, and laying it down on the right side, is the easiest way to do the job.
In my case it takes two to pick it up. I use a jack and strap it down. Almost to weak to do it that way as well ! LOL
with my right shoulder all bunged up, I am afraid that I would not be able to pick mine up again either.
Dang it, but that rock last March, damn sure ruined a good shoulder.
doing lots of PT every week now for six weeks, it is better, but no where near normal.
I can comb my hair now with my right hand, just barely, but I cannot reach behind my neck like I can easily with my left hand.
2012 ... I do the layover method now also...
PIA do take passenger arm rests off, seat off, rear center fender, center portion of hitch, unplug connector for amplifier, remove bolts for inner fender and crossmember strut for inner fender and remove the whole thing.
My amplifier connector under the seat absolutely would not come out the rear without me modifying the inner fender. No matter what i tried there was not an area larger enough for that huge connector to fit through.
Hitch strut is definitely in the way now for connector to come through and would have to be removed also besides the center portion of Bushtec hitch.
IF you are not doing the layover method. OR don't have a lift to drop the wheel down.
You have to take the seat off to get to the amplifier connector to disconnect and fish it back up to reconnect.
good reason to not put any electronics in the trunk
Amplifier is stock Honda above rear wheel in inner fender.
The owners manual shows how to remove rear wheel.
Thank you. I was having a bad case of what the ____.
First step for just about anything (especially on a 1500) is "remove the seat". :ROFL: At least you don't have to do that to check the oil....
  • Like
Reactions: Bellboy40
If you have a trailer to put ot on or a lift:
Use center stand and strap it so it can't fold up. Drag the bike back to hang the rear wheel in mid air and strap the bike down.
Discussion Starter #19
Frankly laying a new,$25000,900 pound bike on its side,and hoping for no damage is a roll of the dice! And using a lift that jacks up bike on the motor and exhaust pipes( there is no downtube
aka like a Harley,and it’s possible u can dent the exhaust pipes, so I guess I’ll follow the manual,and take the extra 20 minutes (I hope) to remove tire, but thanks for all the advice.
You don't lift it by the exhaust pipes. One pad goes under the center stand pivot and the other under the front of the engine. The only way it gets damaged laying it on it's side is if you have some kind of mishap or lay it on bare concrete, gravel etc.
1 - 20 of 54 Posts
