1 - 3 of 3 Posts
As the title says, is there a way I can see if the plunger is actually moving on the carb? I was gonna pull the tupperware to check, but didn't want to waste my time if I cant see it. I don't mind pulling the carbs, just don't have the time right now...
Thanks!
The Irish Crew
No easy way to check as the linkage is at the very front of the carbs. Some plastic stripping needed.
Does the RPM change as you work the choke? From reading your other post I think you may have the enrichment circuit plugged.
1 - 3 of 3 Posts
