Does the fuel pump turn on when the key is in the on position or only when the motor is running? Right now my only comes on when the motor is running.:?
It should run for a couple of seconds when you turn the key on, then runs when starting or running.
Thanks Dave I will see if that is the case
Fuel pump came on for a few seconds, then started to run when the motor started. got 20 oz of gas in less than 1 minute. gas came out cloudy, I am going to drain gas tank and put new gas in it.
Anti-Guru
You may wanna change your filter too -- cloudy is not really something that you should see if the 10-micron OEM filter is clean...
Thanks I plan to pick one up to day and change it.
