I don't know where to begin to troubleshoot my problem. I swapped out a GL1500i engine, which had a bad transmission, with a GL1500A with 5800 miles on it. All wiring is hooked up, the battery is fully charged but I must be missing something or have something hooked up wrong. I don't get any lights on the gauge cluster. The starter switch Hot (+) reads 13+ volts. The fuseable link is hot. When I turn the key on, the horn functions. Also turning the key on and off does produce a click sound coming from the fuse panel. But the starter does not turn and again, no lights on the gauge cluster.
SIDE NOTE: I have the rear carriage off because the rear wheel is removed. Also, I have no lights installed on the wing at present; including headlight, taillights, turn signals, saddlebag lights etc. because all the tupper ware is currently off to be repainted. I'm sure that's irrelevant but just wanted to fully explain the existing appearance of the wing. Any and all help is greatly appreciated whether or not it produces favorable results. I can talk or text at 419-420-5162 if that's easier. I need to know what what I can test next to lead me to the problem.
Kevin
Kevin
