question other than randakks carb kit. what kit would you suggest for ME. i plan
on reusing the brass parts and leaving carbs attached to plentum. kinda just a o-ring kit???
bobaloo took your advice and had pistol pete rebuild the carbs.
found broken return cable now having trouble getting em hooked
up on the carb?? any pictures??
ok got a lot put back together. i was going to flush out the fuel pump
but i can not get gas to flow out the pump??? any help??? or ideas??
pet **** open new filter on the right way, gas in filter but not pumping
through???
I think you beginning to see value in what you've invested , as you have posted a sentry to keep guard
You might want to use a small container of gasoline to at least get the bike running . Just fix it up on gravity feed . If the bike starts up then the mechanical pump may begin to work , so be sure to put its outgoing line into a catch container.
through???[/quote]
The check valves in the pump may be stuck. A little pressure may pop them loose.
thanks guys. hooked it up to over head gas. started right up.
i should thank pistol pete. ran it sever minnutes tapping on
fuel pump many times nothing?? looks like i need a new fuel pump.
ok took fuel pump apart now its working thanks.
fuel and temp gauges not working. looks like i
need a 7 volt regulator. my question is i have a broken
o ring with a metal housing that broke.
is this the right spot where it goes??
and is it part #15 on the parts list??
DavrO430 wrote Looks like spare junk to me. No, the 7v reg is a little metal box inside the instrument panel.
i think your right..
got the 7 volt reg.in gas and temp gauges now working. thanks all..
took the back wheel off again and took a picture. there is still the broken o-ring with a metal housing im unsure
where it goes i have parts list picture up a couple posts?? any help??
Unfortunately I'll be parting out a 1985 GL1200. Long story short, it's title is lost so I'm parting it out. I've stripped off the bags, tourpack, fairing etc for sale and I'd like to wire up the engine to get it running. Can anybody advise me on which components I'll need from the bike to make...
Sometimes you just want a job done by a pro, don't have time to tackle a project, or don't want to invest in tools you know you'll need.
It may be a good dealership, or individuals working out of their garage...don't matter as long as the skill is there.
For me, I need someone I...
Hello Y'all, I'm back... In March of 2017 I joined this site because I was about to pick up my "new to me" GoldWing, a 1986 Interstate with 25000 miles. I received a lot of good advice on how to proceed with my project, unfortunately, as does so often happen, life reared it's sometimes ugly head...
It is easier on Xenforo than it was before, but ......
Okay,
as we move along and become more familiar with XenForo, it is easier to use in a lot of respects, BUT ya hafta have prior experience to know what you can do....
Just now, I wanted to send a PM to a user.
I wondered if I could just...
