While in New York My starter stayed electrically engaged for a few seconds after a start. It disengaged after I turned off the key and restarted. I had no more problems the next two weeks while on the way home. Today I went to get a cigar and when I started the bike the starter stayed engaged again. Turning off the key had no effect on the stopping the stater. So I was just 1/4 mile from home so I just drove it home with the starer running. But when I entered the garage the starter stopped and I turned off the key.
Now I have read on this forum it could be the starter relay. I see two relays with heavy cable going to them one near the positive batter terminal and attached the battery box with a rubber holder, one, much lower and forward near rear brake peddle after you remove the plastic cover.
Which one is the possible bad relay and what do both do. Both make a click when you hit the starter button and if you remove the black cable from the lower relay and hit the starter button the relays click but no power the starter motor.
RICK
P.S. We had a Great trip 14 states and Canada 3900 miles one starter scare in new york
RICK
