I think we are on to something,it is a definite increase in neutral and up. The increase is 400-600 rpm and is the same all the time.
Looks like my base idle in first, is probably set right.
Just have to figure out why its higher than 100 rpm, going into higher gears.
Have downloaded the manual and will go thru the steps.
Sounds like I will be pulling off some panels, checking for electrical connections, vacuum and air leaks.
Keep you informed till I get it in line, not getting a lot of time to work on it.
